As promised, here is Post 1 in the new series of Creo tips from our expert product managers.
Each post includes about 15 minutes of video how-tos aimed at skilling up your CAD proficiency—whether you’ve just started using Creo or consider yourself an old pro.
So much for the ado. Let’s jump in!
You can pass any type of geometric reference information and user-defined parameters to and from parts, skeleton models, and assemblies using the Copy Geometry feature. Normally, you can only copy geometry (like curves, surfaces, or datum planes) from a single source component.
However, in this tutorial, Creo Product Manager, Arnaud van de Veerdonk shows you how to manually copy geometry from multiple assembly components using a single shrink wrap feature.
Watch how to do it:
Simplifying a model by removing small geometric features, holes, and areas that increase the complexity of the mesh can speed up analysis and simulation processes. But you might find it time-consuming to remove these features manually.
In the tutorial below, Martin Neumueller, Director of Product Management, shows how to quickly defeature a model in preparation for simulation with flexible modeling and geometry search capabilities provided in Creo Simulate and Creo Parametric.
You've maybe noticed that Creo creates default, context-sensitive transitions when you add rounds to a model. These are just the default and, like most other elements, they can be changed to fit your needs.
In this short tutorial Paul Sagar, VP of Product Management, shows you 3 tricks for creating advanced round geometry inside Creo. You'll learn how to:
Watch this short tutorial to learn how:
For more tips from our experts, watch the Tips from the Creo Masters main page.
