Jun 3, 2022 12:44 PM UTC
Creo Parametric 9.0 Manikin
  • Apr 9, 2026 5:44 PM UTC
  • 3 replies
  • 1262 views
  • Translate All
Check out this video on Creo Parametric Manikin from PTC Application Engineers
Presenters: Lee Goodwin (Solution Consulting, Principal) and Lino Tozzi (Solution Consulting, Fellow).
Jun 8, 2022 8:26 PM UTC
Webcast Q&A
Question from Anonymous:  Does Creo Design Advanced come with the Human Factors Extension?
Answer:  Yes, it is available with all newer subscription licenses.
Jun 8, 2022 8:29 PM UTC
Webcast Q&A
Question from Christopher:  I loaded Manikin library into Windchill years ago and never updated it since.  You mentioned Creo 9 changes something.  What have we missed?
Answer:  It has been updated.  You would only us the Creo 9 library if you are using Creo 9.  If you are not, then use the existing one from Creo 1.
Jun 8, 2022 8:33 PM UTC
Webcast Q&A
Question from David:  Does the mass of the manikin alter the suspension geometry of the motorcycle (in this instance)?  Valuable to know for reaching the ground concerns.
Answer:  You would not use Manikin for a Mechanism like study.  However, you do have the Center of Gravity for the manikin and you can place the mass at the point.
