Check out this video on Creo Parametric Manikin from PTC Application Engineers
Presenters: Lee Goodwin (Solution Consulting, Principal) and Lino Tozzi (Solution Consulting, Fellow).
Webcast Q&A
Question from Anonymous: Does Creo Design Advanced come with the Human Factors Extension?
Answer: Yes, it is available with all newer subscription licenses.
Webcast Q&A
Question from Christopher: I loaded Manikin library into Windchill years ago and never updated it since. You mentioned Creo 9 changes something. What have we missed?
Answer: It has been updated. You would only us the Creo 9 library if you are using Creo 9. If you are not, then use the existing one from Creo 1.
Webcast Q&A
Question from David: Does the mass of the manikin alter the suspension geometry of the motorcycle (in this instance)? Valuable to know for reaching the ground concerns.
Answer: You would not use Manikin for a Mechanism like study. However, you do have the Center of Gravity for the manikin and you can place the mass at the point.
