Check out this video on Creo Parametric Advanced Framework Tips and Techniques session from PTC Application Engineers.
Presenters: Lee Goodwin (Solution Consulting, Principle) and Ryan Butcher (Solution Consulting, Fellow).
Creo Advanced Framework Learning
- Chapters
- descriptions off, selected
- captions settings, opens captions settings dialog
- captions off, selected
This is a modal window.
Beginning of dialog window. Escape will cancel and close the window.
End of dialog window.
This is a modal window. This modal can be closed by pressing the Escape key or activating the close button.
Webcast Q&A
Question from Adam: Does Creo have a 3D sketching function like SolidWorks does? That function in their "weldments" extension made it very fast to create a 3 Dimensional skeleton to make tube frame structure.
Answer: Use curve through points, or curve from intersect. Contact me for a demonstration, if you would like. rbutcher@ptc.com.
Question from Adam: Is there an auto-generated cutlist for drawings?
Answer: Yes
Webcast Q&A
Question from Eric: Is it possible to make a custom size beam?
Answer: Yes. This can be done by editing the files that present Profiles in the library.
Webcast Q&A
Question from Paul: Are these features available in Creo 7?
Answer: Yes, this is available in all Creo releases.
Graham Croxford
Mechanical Design Engineer
Fisher & Paykel Technologies
T +64 (9) 2730600 | M 0064210583639
Fisher & Paykel Appliances Ltd
78 Springs Road
Auckland 2013
New Zealand
