Nov 29, 2022 3:36 PM UTC
Creo Parametric Ansys Simulation Tips and Techniques
  • Apr 10, 2026 6:28 PM UTC
  • 3 replies
  • 1889 views
  • Translate All
Check out this video on Creo Parametric Ansys Simulation Tips and Techniques session  from PTC Application Engineers.
Presenters: Lino Tozzi (Solution Consulting, Fellow) and Ryan Butcher (Solution Consulting, Fellow).
Creo Ansys Simulation Learning
Dec 6, 2022 8:55 PM UTC
WEBCAST Q&A
Question from Anonymous:  Does Creo Simulate have model validation capabilities?  Or is there another feature in Creo that can be used to check assemblies with overlapping parts, etc. or is this not possible in Creo?
Answer:  Validating models can be done with Interference Checks and ModelCheck, which is included in every seat of Creo Parametric.
Dec 6, 2022 9:00 PM UTC
WEBCAST Q&A
Question from Kevin:  What is the CPU limit for Creo Simulation (Mechanica)?
Answer:  to run Creo Simulation Live, PTC recommends the following minimum hardware:  A dedicated NVIDIA CUDA-enabled GPU card (Quadro recommended) based on the Kepler, Maxwell, or Pascal architecture.
https://www.ptc.com/it/support/article/cs302825
Quadro M4000
Quadro P4000
Quadro RTX 4000
Quadro RTX 5000
Quadro RTX 6000
Dec 6, 2022 9:04 PM UTC
WEBCAST Q&A
Question from Raghu:  I am seeing Ansys Simulation on the top menu, but don't see any mesh!  I am a bit confused.  I thought Creo Ansys Simulation models have a mesh.  Is that not true?
Answer:  Yes, it uses the Ansys physics based mesh.
Question from Raghu:  But I do not see "Mesh Control" in the model tree, didn't see the mesh in the graphics window.
Answer:  It is under the "Refine Model" tab.
