Jan 19, 2024 9:24 PM UTC
Creo Patterns Tips & Techniques Session Recording (East Coast)
  • Apr 7, 2026 8:38 PM UTC
  • 3 replies
  • 173872 views
  • Translate All
Check out this video on Creo Additive MFG from PTC Application Engineers.
Presenters: Jason Petersen (Solution Consultant, Principle)  & Lino Tozzi (Solution Consultant, Fellow)
Original Date Presented: January 18th , 2024
Jan 30, 2024 9:01 PM UTC
WEBCAST Q&A
Question from Derek:  Can the standard hole note be modified or customized?
Answer:  Yes, those can be modified/customized.  This link should help:  https://www.ptc.com/en/support/article/CS28399?source=search
Jan 30, 2024 9:06 PM UTC
WEBCAST Q&A
Question from Matt: Can you still omit instances?
Answer:  Yes, that is still available.
Jan 30, 2024 9:21 PM UTC
WEBCAST Q&A
Question from Scott:  Not sure if this will be covered in the assembly patterns, but I'll submit my biggest question/grip with patterns ahead of time.  Often we will pattern groups of components in a higher assembly (i.e. 6 patterns for 6 cylinders on the engine).  The issue with patterns is that once a group is patterned, the group cannot be changed.  So, I cannot delete a part from a group that is patterned.  I'm using Creo 7 but moving to Creo 10 soon.  Does Creo have this functionality in Creo 10 or will it be in the future?
Answer:  Not with Creo 10.  This would be a future enhancement.
Question from Scott:  Another feature I'd love to be more efficient with is patterning a table.  Any efficiency or UI tips with using that table would be appreciated.  The window that pops up to edit the table seems a bit clunky, but maybe I'm just not sure how to use it efficiently.
Answer: There is no new functionality for table patterns.  This is a future enhancement.
Question from Scott:  Can you confirm what you selected to pattern?  I think I missed that.  Did you select the Foot_support group from the model tree?
Answer:  That was a part.  It was all the parts merged into one.
