Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
The Flexible Modeling Symmetry Recognition feature locates mirror-symmetrical geometry and builds new symmetry logic to the design intent. For example, the Symmetry Recognition feature is possible to use for Flexible Move.
