The PTC Community will be on read only status starting March 23rd in preparation for moving our platform to a new provider. Read more here
How to change the system colors in Creo Parametric
No ratings
In this video, we will learn to
  • customize the system color
  • set background color to display a gradient between two colors
Comments
I recently update to Creo 8.0.2. In previuos versions, it was possible to have the edge of the planes of two different color (one for the positive side, one for the negative side).
In Creo 8 now only the surface of the planes is colored (one for positive, one for negative) but not the edge fo the planes. The edge are the same color for both sides.
How can I set this in Creo 8?
Thank you.
@bchen
Hi @fgosti ,
You may want to use the config option "enable_legacy_datum_planes" set to "yes" to get previous Creo release's display.
See article CS350123
Thx
@cgorni thank you very much! You are the best!
Version history
Last update:
‎Dec 15, 2021 03:33 AM
Updated by:
Labels (2)
Tags (2)
