How to install Creo Parametric 3.0, Creo Simulate 3.0, Creo Direct 3.0 and Creo Layout 3.0
Amethyst
  • How to perform installation
  • How to install  using install-from-web
  • How to install a node locked license
  • The drag and drop of the license does not work
  • How to install software
  • Unable to install by adding SON under simple license entry
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
6 REPLIES 6
Re: How to install Creo Parametric 3.0, Creo Simulate 3.0, Creo Direct 3.0 and Creo Layout 3.0
Thanks for the video
Its shows how to install locally, but how do you install on a mapped drive?
I have same problem with network installation, as I create locally installation first, copy-paste the
installation to my network disc and edit *.bat and *.psf files manually.
Yes, I know this Work around
But I think it is quit annoying, because we have a lot of different licenses and different startup configurations so it takes a lot of time and possibilities of errors.
I'm sure there must be quit a lot Companies with the same problem, so an easier installation approach would be very much appreciated
Regards Peter
O.K.
Other way, you can create the installation from computer that doesn't has local installation of Creo 3.0.
Leonid
Can you please tell me how to download latest creo version ?
You have to log in to PTC Esupport https://support.ptc.com/appserver/cs/software_update/swupdate.jsp
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
