MultiAxis Milling w Creo NC Tips & Techniques Session Recording (West Coast)
No ratings
Check out this video on MultiAxis Milling w Creo NC from PTC Application Engineers
Presenters: Lee Goodwin (Solution Consultant, Principal) and Ryan Butcher (Solution Consultant, Fellow)
Original Date Presented: October 17, 2023
To dive deeper into the subject, check out MultiAxis Milling.
Comments
WEBCAST Q&A
Question from Alex:  Does changing the retract surface to a curved surface reduce the accuracy of the machining?
Answer:  No, basically it should only effect the start and stop in your toolpath.  It controls the amount of pull out only.  It will only effect the entry and exit.
WEBCAST Q&A
Question from Dennis:  Can you split the toolpath so the next tool starts where the first one ended?
Answer:  It won't remember the last position of the tool in the 1st toolpath to start there on the 2nd toolpath.  Something that works well for this is using "at a location" for axis control.
WEBCAST Q&A
Question from Wayne:  Is there a collision detection option so we don't have to check only by eyeballing it?
Answer:  Yes, you can turn on and off collision detection.  The main thing that eyeballing does is it helps with deciding how to fix a problem with the toolpath.
Version history
Last update:
‎Dec 04, 2023 02:28 PM
Updated by:
Labels (3)
Contributors
