What's New in Creo 8 & 9
No ratings
Check out this video on What's New in Creo 8 & 9 from PTC Application Engineers
Presenters: Lee Goodwin (Solution Consulting, Principal)
Comments
Webcast Q&A
Question from Andrew:  When it becomes inseparable does the model become more light weight for rendering purposes?
Answer:  The rendering is geometry based.  The geometry is not changing so rendering should be no different.
Question from Andrew:  Can you then re-run the generation to make the associated keep out after removing the beam?
Answer:  No, this is after the fact.  It does not stay removed when you re-lattice.
Question from Andrew:  We call out surface finish via note and leader with colored faces.  Is the new call out able to reflect the faces it references?
Answer:  Yes, this was update in Creo 7.0.  Divide in 9.0 if you only want parts.
Question from Andrew:  Is that only for MDB?
Answer:  Divide surface is an OOTB 3D function.
Webcast Q&A
Question from Julio:  Are the some improvements for drawings?
Answer:  Yes, sketching and symbols.
Webcast Q&A
Question from Kathryn:  Is there a way to see the amount of interference?
Answer:  In part mode the volume of interference region is displayed.
Webcast Q&A
Question from Roger:  Is exporting inseparable assemblies a planned feature?
Answer:  No, just for imported models into Creo.
Webcast Q&A
Question from Vasi:  In a drawing, BOM table is still working with the inseparable assemblies?
Answer:  Yes, there is a config option.
Version history
Last update:
‎Jul 05, 2022 03:45 PM
Updated by:
Labels (1)
Tags (1)
