CREOSON (OpenSource Automation) - v2.4.0 is Available
DavidBigelow
Just wanted to let you all know that CREOSON v 2.4.0 (Open Source automation via JSON Transactions for Creo Parametric) is now available with a few fixes, improvements and new functions.
  • New functions: parameter.set_designated, feature.list_group_features, feature.list_pattern_features.
  • The documentation has been fixed for feature.list and feature.list_params; those two pages had been mixed together as "feature.list" in previous releases, but there should have been two separate pages.
  • A couple of changes to file functions for handling MFG models.
  • Validation has been added to check for missing "command" or "function" inputs in all JSON requests.
  • In the interface.mapkey function, newlines will now be stripped from the mapkey before it is sent to Creo.
You can obtain the latest distribution here --> CREOSON GitHub Releases
Dave
0 REPLIES 0
