Hi Guys,
I have a requirement where I need to call toolkit method in OTK C++.
Need to check if following attached code is right?
Application hangs up while executing the code.
CODE:
pfcDimension2Ds_ptr dims = drawing->ListShownDimensions(vw->GetModel(), pfcModelItemType::pfcITEM_DIMENSION);
for (int j = 0; j < dims->getarraysize(); j++)
pfcDimension2D_ptr soldimension2d = pfcDimension2D::cast( dims->get(j));
pfcDimension_ptr solDimension = pfcDimension::cast( dims->get(j));
if (soldimension2d->GetIsDisplayed())
if (soldimension2d->GetView() != NULL)
try
ProDimension feat = (ProDimension) wfcGetHandleFromObject( pfcObject::cast(solDimension) );
double *valD;
ProDimensionDisplayedValueGet(feat,valD);
}xcatchbegin
xcatchcip (Ex)
wLogger->log("ERROR IN Inspection Report Method....................");
cout<<Ex;
xcatchend
}// View associated to dimension
}// Dimension is displayed
}// Iterate dimensions
I am not sure is there any way to directly call Toolkit API's.
Correct way of calling Toolkit API into otk is load DLL which has toolkit API and call it,
Go through API the document where it shows how to use otk API's
Following is the API document on how to use toolkit API,
Launching a Creo Parametric TOOLKIT DLL
The methods described in this section enable a Creo Object TOOLKIT C++ user to register and launch a Creo Parametric TOOLKIT DLL from a Creo Object TOOLKIT C++ application.
Methods Introduced:
•pfcBaseSession::LoadProToolkitDll
•pfcBaseSession::LoadProToolkitLegacyDll
•pfcBaseSession::GetProToolkitDll
•pfcDll::ExecuteFunction
•pfcDll::GetId
•pfcDll::IsActive
•pfcDll::Unload
Method "ExecuteFunction" can be used to call toolkit API
@bdhamdhere wrote:
Hi Guys,
CODE:
try
double *valD;
}xcatchbegin
xcatchcip (Ex)
cout<<Ex;
xcatchend
whatever is colored in red is wrong. you cannot declare a pointer to a double an pass it to a function. the function has nowhere to store the resulting value - it is trying to write sizeof(double) bytes to a space allocated for sizeof(*double). you need to declare a double and pass a pointer to a double to the function...
the second highlighted thing (feat) is wrong - you cannot pass the structure by value to the function which expects a pointer to a structure...
double some_value = -1e6;
if( PRO_TK_NO_ERROR != ProDimensionDisplayedValueGet( &feat, &some_value)) {...}
