Is there an API to change Creo's window size to a specific size?
Or could it be implemented using other APIs? (Ex. Windows API)
If possible, Please teach me how to implement.
You might try these environment variables by appending to your Creo *.psf file:
ENV=UI_DISPLAY_SCALE=100
ENV=UI_SCREEN_SIZE=1920x1080
ENV=UI_SCREEN_RECT=0,0 1920x1080
