Change Drawing Sheet format Using VB.NET (Sheet Setup)
bsomasundaram
Hi Guys,
I need to change Drawing Sheet format Using VB.NET, I tried with below coding and I am getting error while "fdescr = (New CCpfcModelDescriptor)."
Please help to solve.
Coding:
            If Not lmoddoc Is Nothing Then
                Dim x As Integer
                Dim sheets As Integer
                Dim sheetdata As IpfcSheetData
                Dim sheetformat As IpfcDrawingFormat
                Dim drwonr As IpfcSheetOwner
                Dim fdescr As IpfcModelDescriptor
                Dim drw As pfcls.IpfcDrawing
                Dim drwl As IpfcLayout
                Dim bsession As IpfcBaseSession
                Dim drawing As IpfcDrawing
                lmoddoc.Display()
                session.CurrentWindow.Activate()
                model = session.CurrentModel
                drawing = CType(model, IpfcDrawing)
              fdescr = (New CCpfcModelDescriptor).CreateFromFileName("C:\Program Files\PTC\Creo 2.0\Common Files\F000\creo_standards\formats\a4_format.frm")
                Dim fmt As IpfcDrawingFormat
                fmt = session.RetrieveModel(fdescr)
                drwonr = CType(drawing, IpfcSheetOwner)
                drwonr.SetSheetFormat(1, fmt, 1, Nothing)
            End If
Error:
Please find attached file for error report
Could you Please confirm whether my code is correct or wrong when i try to retrievemodel
if it is possible to update current drawing sheet width and height, its very useful.
Hi Balaji,
according to the documentation, CreateFromFileName expects the name in this form:
The file name, of the form "<name>.<extension>"
Try to set the working directory to the required path or set search_path to that directory and call CreateFromFileName("a4_format.frm")
Tom
Hi Tomas,
Thanks for your reply.
As per your instruction, i have updated my config.pro file for search_path = "C:\Program Files\PTC\Creo 2.0\Common Files\F000\creo_standards\formats"
and updated the code like
fdescr = (New CCpfcModelDescriptor).CreateFromFileName("a4_format.frm")
after updation new error occurred while run the code at line of
Error Image:
I think i have some problem in retrieve process. Please help.
Balaji
