Hello
I would like to set coincident constraint. I am using API ProAsmcompconstraintTypeSet().
I am not able to get what should be set for argument "ProAsmcompConstrType" into API.
Possible values for ProAsmcompConstrType are as below as per user guide:
PRO_ASM_MATE, PRO_ASM_MATE_OFF, PRO_ASM_ALIGN, PRO_ASM_ALIGN_OFF, PRO_ASM_INSERT, PRO_ASM_ORIENT, PRO_ASM_CSYS, PRO_ASM_TANGENT, PRO_ASM_PNT_ON_SRF, PRO_ASM_EDGE_ON_SRF, PRO_ASM_DEF_PLACEMENT, PRO_ASM_SUBSTITUTE, PRO_ASM_PNT_ON_LINE, PRO_ASM_FIX, PRO_ASM_AUTO, PRO_ASM_ALIGN_ANG_OFF, PRO_ASM_MATE_ANG_OFF, PRO_ASM_CSYS_PNT, PRO_ASM_LINE_NORMAL, PRO_ASM_LINE_COPLANAR, PRO_ASM_LINE_PARL, PRO_ASM_LINE_DIST, PRO_ASM_PNT_DIST, PRO_ASM_INSERT_NORM, PRO_ASM_INSERT_PARL, PRO_ASM_PNT_ON_LINE_DIST, PRO_ASM_PNT_ON_SRF_DIST, PRO_ASM_EDGE_ON_SRF_DIST, PRO_ASM_EDGE_ON_SRF_ANG, PRO_ASM_EDGE_ON_SRF_NORMAL, PRO_ASM_ALIGN_NODEP_ANGLE, PRO_ASM_MATE_NODEP_ANGLE, PRO_ASM_LINE_ANGLE, PRO_ASM_EDGE_ON_SRF_PARL, PRO_ASM_SRF_NORMAL
I am having Creo 3.0 M120.
Any thought would be of great help.
THanks and Regards
Ketan
