Copying a non pro/e file
msteffke
Guru's
In Pro/Toolkit I'm visiting components in assembly, and exporting
drawings as a cgm file to a temporary workorder folder. There are
certain parts that are standard, and I would rather just copy the
existing .cgm from the master cgm folder to my workorder job folder.
How can I copy a file within the program, is there a toolkit function or
any filecopy function? Not looking for exact syntax, just a rough of
what method to use.
Mark Steffke
Engineering System Administrator
The Delfield Company
Manitowoc Foodservice
T 989.775.9215 or 989.773.7981, ext 12484
Integrity, Commitment to Stakeholders, and Passion for Excellence
msteffke
(To:msteffke)
Or is there a way to call a dos batch file from within your dll?
Mark Steffke
vinaym
(To:msteffke)
There is a system() function to run any command which is platform
independent.
system() call has a side-effect. On windows it opens a dos window when
executing command (like copying a file) which is annoying for the user.
I would suggest to use CopyFile() function on windows.
msteffke
(To:msteffke)
Thanks, good advice. Will give that a try.
Mark Steffke
The system() call will display the command prompt window. Rather, try
CreateProcess().
Alternatively, write your own code to copy the file.
Bob
Bob Monat
Jerand Technical Services, Inc.
bob@jerand.com
www.jerand.com
1-317-875-6087
On Fri, Jan 25, 2013 at 3:48 PM, Steffke, Mark J <mark.steffke@manitowoc.com<br/>> wrote:
> *Mark Steffke*
> *Integrity, Commitment to Stakeholders, and Passion for Excellence*
