Create a Simple Draft sketch line
msteffke
I m struggling to find a way to create a single draft entity line on a drawing sheet.   Looking to create a line at 0,0 and go to 1,0 (x direction) or from 0,0 to 0,1 (y direction).   Can someone point me in the right direction?
RPN
18-Opal
18-Opal
(To:msteffke)
Yes, that is wrong, thus will only create temporary lines, or items.
One example as well in UgDtlentityExamples.c
FUNCTION : UsrLineentityCreate()
PURPOSE : Utility to create a line entity between specified points
7 REPLIES 7
JB_87049
(To:msteffke)
Sorry, misinterpreted the question. This is about Toolkit.
msteffke
(To:JB_87049)
My bad.  Yes I am trying create the line in ProToolkit, with no user input.  Want the line to appear automatically.
RPN
18-Opal
18-Opal
(To:msteffke)
You need the Matrix of ProDrawingBackgroundViewGet()
The window matrix is required as well, because as far I remember x,y,z are screen coordinates.
Multiply the line coords by using the inverse (?) with the Window Matrix, something like this, beside of creating the line.😉
There should be an example in the folder tree.
msteffke
(To:RPN)
Thanks 17-peridot,  Is the function to create the line  ProGraphicsLineDraw ?    The line i am creating represents the grain direction on a stainless steel sheetmetal flat.   If I have the line on a special layer it can let our CNC nesting software know the direction of grain constraint.  The line is to be on a drawing with a view of the flat.
/* Transform points by matrix */
    ProUtilPointTrans( trf_matrix, point1, point1 );
    ProUtilPointTrans( trf_matrix, point2, point2 );
    /* Draw the line */
    ProGraphicsPenPosition( point1 );
    TEST_CALL_REPORT( "ProGraphicsPenPosition()", "ProTestGraphicsLineDraw()",
			(ProError)0, 0 );
    ProGraphicsLineDraw( point2 );
    TEST_CALL_REPORT( "ProGraphicsLineDraw()", "ProTestGraphicsLineDraw()",
			(ProError)0, 0 );
FV
(To:msteffke)
Mark you are using a wrong API, what you need is ProDtlentityCreate(...). There is  protk example file TestDtlentity.c with working code.
HIH
msteffke
(To:FV)
Thanks I will take a look at that!.
RPN
18-Opal
18-Opal
(To:msteffke)
