Create custom properties on part object
ptc-3191571
I have a requirement in which I want to mark part with some identifier property.Is it possible to set such custom properties on ProMdl like objects? Any other way available using which I can add identifier using Pro/Toolkit? Thanks
Yes you can create a parameter (ProParameter) and set it's value.
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
[cid:image001.jpg@01CCCAB7.00B3EFC0]
