Creating Flattening Harness
Say for Example I have 20 wire routed, out of which
1) 10 wire follow network path A
2) 5 wires follow network path B
3) another 5 wires follow network path C.
While creating flatten harness it will ask for start point when we give start point it will create flatten Harness only for
a) 1st 10 wires following network path A
and i will have to create 2 more separate flatten harness for 5+5 wires passing through Network Path B and Path C.
I want to know is this the right procedure? or I can create one single Flatten Harness for all the 20 wires passing through different network path that is "A","B" and "C".
