Hi Team,
I want to keep custom settings in Creo in such a way that whenever I create a hole in the model. The Hole location and it's depth dimensioning should have 2 decimal places by default in the drawing.
Also, I want to set The angle of the hole as basic by default. Is there any possibility without affecting other things' tolerance in 2D Drawing? The rest of the dimensioning should be per Creo default.
I would appreciate any solution for the above request. Thanks so much in Advance.
Have considered using a user defined feature (UDF) for your custom hole feature? You could create model annotations (dimensions) for the hole and control the dimension display in the model and then show those annotations in the drawing configured as required independent of other drawing dimensions.
You could also create a drawing symbol of the hole detail view(s) and place the symbol on any drawing without affecting the drawing settings. This would be a "generic" representation of the hole feature and dimensions.
