Creo Toolkit : How to Save .pvz and .png using toolkit.
  • August 7, 2017
  • 9 replies
  • 5615 views
Hello all,
 I am using toolkit (c++) and want to save .pvz and .png of current part/assembly/drawing
with no options selected from Spin Center and Datum display filters.
Please let me know if you have any code sample/ function name which can help me.
Warm regards,
Madhavi
Best answer by Madhavi
@Eike_Hauptmann
Below is the solution to it Woman Happy
ProConfigoptGet to get the current value ( for example "AXIS_DISPLAY").
if it's 'yes' then set it to 'no' to hide the ConfigOption.
Once desired task is done then it can be re-set to original value!
Woman Very Happy
AFAIK png isn't supported atm. But could be wrong. JPG would be
JPG:
ProRasterFileWrite(win_id, PRORASTERDEPTH_24, width, height, PRORASTERDPI_600, PRORASTERTYPE_JPEG, ppath);
PVZ:
ProProductviewexportoptsAlloc(&opts);
ProProductviewexportoptsFormatSet(opts, PRO_PV_FORMAT_PVZ);
ProProductviewFormattedExport(mdl, ppath, pfile, opts);
ProProductviewexportoptsFree(opts);
Br,
Eike
Madhavi1-VisitorAuthor
Thanks Eric.
I happened to find this solution too and your reply just comfirmed my solution.
But that just solves half of the problem.
I do not want "options selected from Spin Center and Datum display filters."
Do you have any idea how to remove it temporarily (just before exporting .pvz, .bmp) ?
I think datums could be very easy by pushing them to a layer and hide it. (So there are rule based layers and you can do it from a template model by the Toolkit API).
Spin center is a little bit more difficult dependend on the Creo Version you're working with. So I know in Creo 4.0 you can use a Macro like : ProMacroLoad("~ Command `ProCmdViewSpinCntr`  0;"); ProMacroExecute(); I think in Creo 2.0 this isn't possible because you didn't get the current status of this button. Creo 3.0 I don't know.
Br,
Eike
3-Newcomer
August 23, 2022
HI Madhavi,
I am not able to understand the code you are trying to use for the task. can you please the code from starting , it will be help full for me a lot.
Thanks inAdvance
Abdul
