I want to query font-size of text-lines in detail notes, and if it does not match certain specification change color note. This is not working as expected due to two reasons -
- It returns invalid font size. When I manually check the height, it shows 6mm. Whereas when I query it on TextLine, it is showing 10.7. Not sure what is correlation.
- I changed color on the DetailNoteInstructions and then tried to set it through DetailNoteItem.Modify, it throws an exception. So I tried creating a new NoteInstructions object. But this results in ProE crash without any warning.
Anybody has faced any of these issues? How to correct it?
