Drawing.Export throws Exception XtoolkitCommError
hamzawaseem
Hello Everyone,
Thanks for helping me before, I have another problem which may need your assistance.
I am trying to export drawing files to PDF using JAVA (Jlink) with CREO PARAMETRIC. The code works, but sometimes, specially while exporting drawings that have assemblies, the Export function throws a Exception
XToolkitCommError.
Code:
PDFExportInstructions Mypdfexportinstructions = pfcExport.PDFExportInstructions_Create();
PDFOptions Myoptions = PDFOptions.create();
PDFOption MyPdfOption_Color = pfcExport.PDFOption_Create();
MyPdfOption_Color.SetOptionType(PDFOptionType.PDFOPT_COLOR_DEPTH);
MyPdfOption_Color.SetOptionValue(pfcArgument.CreateIntArgValue(PDFColorDepth._PDF_CD_COLOR));
Myoptions.append(MyPdfOption_Color);
PDFOption MyPdfOption_Layer = pfcExport.PDFOption_Create();
MyPdfOption_Layer.SetOptionType(PDFOptionType.PDFOPT_LAYER_MODE);
MyPdfOption_Layer.SetOptionValue(pfcArgument.CreateIntArgValue(PDFLayerMode._PDF_LAYERS_NONE));
Myoptions.append(MyPdfOption_Layer);
PDFOption MyPdfOption_Launcher = pfcExport.PDFOption_Create();
MyPdfOption_Launcher.SetOptionType(PDFOptionType.PDFOPT_LAUNCH_VIEWER);
MyPdfOption_Launcher.SetOptionValue(pfcArgument.CreateBoolArgValue(false));
Myoptions.append(MyPdfOption_Launcher);
Mypdfexportinstructions.SetOptions(Myoptions);
proeDrawing.Export(filename, Mypdfexportinstructions);
For assembly, I call this function in a loop for each part in that assembly.
Please help, stuck here for days!
Hamza
Hamza
Read the following articles:
  1. "Getting XToolkitCommError exception when running a macro from an asynchronous mode customization which takes a long time to update a large model": https://www.ptc.com/en/support/article/CS348237
  2. "Jlink XToolkitCommError occurs when Creo Java Object Toolkit operation is left hanging in Creo JOTK 1.0": https://www.ptc.com/en/support/article/CS198094
  3. "Accessing Property IpfcAsyncConnection.Session randomly throws exception pfcExceptions::XToolkitCommError in Creo Parametric 4.0 M050": https://www.ptc.com/en/support/article/CS291480
  4. "Jlink XToolkitCommError occurs when Creo Java Object Toolkit operation is left hanging in Creo JOTK 1.0": https://www.ptc.com/en/support/article/CS198094
  5. "Error: pfcExceptions::XToolkitGeneralError received while trying to start or connect to a Creo Parametric session through VB API application": https://www.ptc.com/en/support/article/CS46034
