I am trying to call the toolkit function from VB api as per example given in article CS252032.
DLL loaded but ExecuteFunction throws pfcExceptions::XToolkitNotFound error.
Can anyone success in this method. Please guide.
Use #define EXPORT extern "C" __declspec(dllexport) instead of PRO_TK_DLL_EXPORT.
Due to name mangling you might get not found error:
Refer: https://stackoverflow.com/questions/1314743/what-is-name-mangling-and-how-does-it-work
Hi Syalagudri,
Thanks for the solution.
