I have a toolkit that export a table into a text file the way I need it to be ... this part is fine.
The problem I am facing is that some time a cell may have is text on two lines (into the same cell).
Anyone knows if there's a way to export that, right now I am only getting the first line in the cell.
This is the function I am using:
error = ProDwgtableCelltextGet(&CurrTbl, ii, i, ProParamMode(1), CellText);
Here's the solution ... did not find it on my own, got help from PTC
status = ProDwgtableCelltextGet(&tables[iter],1,1,(ProParamMode)1,&getLines); status = ProArraySizeGet((ProArray)getLines,&arrSize);
for(int ii=0;ii<arrSize;ii++) { char buffer[100] = "\0"; ProWstringToString(buffer,getLines[ii]); } status = ProArrayFree((ProArray*)&getLines);
Have a nice day
error = ProDwgtableCelltextGet(&CurrTbl, ii, i, ProParamMode(1), CellText);Thanks
it is quite doubtful that the function arguments are correct.
perhaps 'K&R C Programming Language', chapter #5 would help...
https://archive.org/details/CProgrammingLanguage2ndEditionByBrianW.KernighanDennisM.Ritchie/page/n95
Have a nice day
