Extracting annotation features data via API
  • October 14, 2013
  • 1286 views
Hi all,
I'm using vb API in order to import a Pro E model into my application, I would like to import also
annotation features such as finish surfaces or geometrical tolerances, however when I acces
the annotation features as follows
Dim annotations As IpfcFeatures = solid.ListFeaturesByType(True, EpfcFeatureType.EpfcFEATTYPE_ANNOTATION)
For i As Integer = 0 To annotations.Count - 1
Dim note As IpfcFeature = annotations(i)
Dim params As IpfcParameters = note.ListParams()
Dim subItemFaces As IpfcModelItems = note.ListSubItems(EpfcModelItemType.EpfcITEM_SURFACE)
Dim dimensions As IpfcModelItems = note.ListSubItems(EpfcModelItemType.EpfcITEM_DIMENSION)
Next
all of these data are set to nothing.
Is it possible to access those info programatically?
Any help would be greatly appreciated!
Silvia
Hi Silvia,
Did you find any solution for above query?
I'm trying to read annotation dimensions from a part model.
