I have created group of same diameter hole now i want to get the dimension of that group oh hole and display .How can i do that.
Give you an example, weblink code for the feature dimension
var sess=pfcCreate("MpfcCOMGlobal").GetProESession();
var model=sess.CurrentModel;
var feattype=pfcCreate("pfcModelItemType").ITEM_FEATURE;
var feats=model.ListItems(feattype);
alert(feats.Count)
for(j=0;j<feats.Count;j++){
var feat=feats.Item(j);
var featStatus=pfcCreate("pfcFeatureStatus");
if(feat.Status!=featStatus.FEAT_SUPPRESSED && feat.FeatSubType!=""){
//alert(feat.FeatTypeName);
//alert(feat.FeatSubType);
//alert(feat.Number);
alert(feat.GetName())
var dimtype=pfcCreate("pfcModelItemType").ITEM_DIMENSION;
var dims=feat.ListSubItems(dimtype);
for(var k=0;k<dims.Count;k++){
var dim=dims.Item(k);
alert(dim.Symbol + "the feature dimension is :" + dim.DimValue)
//alert(dim.Symbol)
Sorry , forgot it , some of the alert statements are just want to see the result while i'm testing, so just let it go.
