HELP!!! J-LInk can't setup.
anderson_zm
pro engineer 5.0  run on win7 under vmware.
i'm make sure j-link has been installed.
setup:
1. set working directory to <install path>\...\jlink\jlink_appls\install_test
2. click tools, select auxiliary applications.
3. select <install path>\...\jlink\jlink_appls\install_test\protk.dat
4. name is already in the list
5. select application item, click start, show 'setup of application "InsatllText" failed'
i'm no idea. and can't find any log file.
i'm online waiting for you
Hello, is anyone there?
