Hiding a part annotation in an assembly
CM_10790883
We have many models that were created with an older start part, meaning that some layer rules did not get applied before the model was released. One of these critical rules is to put the auto-generated hole note on a layer and then hide it.
Now we are working in an assembly with these parts in it.  These auto-generated hole notes are showing up at the assembly level.  Is there a way to hide them without revising the already released part?  Is there a layer rule that can be used to collect an annotation from a lower level part and then hide it?
I think that you cannot create a layer containing part entities at the assembly level.
Martin Hanák
What has worked for me with old parts has been to bring them into an assembly that has the layer rules setup to the new standard, select all the layers of interest, then under Layer Operations select Extend  Rules.
Hi @CM_10790883,
Anurag
