How can I connect Creo with Visual Studio to make API?
rkoshevoy
I need to make the API to build the model in Creo. How can I connect  Creo to Visual Studio? I tried the instructions for Pro/Engineer, but it does not work.
joe_c
(To:rkoshevoy)
Which API (there are 4) are you using? can you post the instructions?
There is a user guide available in Creo Toolkit loading folder. This will give you much clear idea about getting started and connected with Visual Studio.
Sachin
