How to Automatically Add Dimensions Using Web.Link
RN_12851263
Hi everyone,
I am new to Creo Web.Link and currently working on automating the process of adding dimensions to a drawing view. My goal is to:
  1. Check if the current model is a drawing.
  2. Allow the user to select a view in the drawing.
  3. Retrieve model annotations (dimensions) from the selected view and display them.
I am trying to use the Web.Link API, but I am facing issues with retrieving and displaying the dimensions. Here’s the function I have so far:
function addDimension() {
if (pfcIsMozilla())
netscape.security.PrivilegeManager.enablePrivilege("UniversalXPConnect");
try {
var session = pfcGetProESession();
var drawing = session.CurrentModel;
if (drawing.Type !== pfcCreate("pfcModelType").MDL_DRAWING) {
alert("Current model is not a drawing.");
return;
alert("Drawing detected. Please select a view.");
// Allow user to select a view
var selectedView = drawing.SelectView("Select a view to retrieve dimensions:");
if (!selectedView) {
alert("No view selected.");
return;
alert("View selected: " + selectedView.Name);
// Retrieve dimensions from the selected view
var annotations = selectedView.ListAnnotations();
if (annotations.length === 0) {
alert("No annotations found in this view.");
return;
alert("Number of dimensions found: " + annotations.length);
// Display the annotations (for testing)
for (var i = 0; i < annotations.length; i++) {
alert("Annotation " + (i + 1) + ": " + annotations[i].Text);
} catch (error) {
alert("Error: " + error.message);
Issues I am Facing:
  • How can I retrieve and display dimensions properly?
  • Is there a way to automatically add dimensions if they don’t exist?
  • Am I missing any required Web.Link methods?
Hi RN_12851263
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
