How to put csys or vertex coordinates into the point of the UDF referenceitem with WebLink.
  • January 10, 2020
  • 1078 views
Hello!!
I'm trying to create a UDF on weblink.
A point of referenceitem is required when creating UDF.
I want to include not only point but vertex (edge-start,end) and csys.
Is there any way??
var session = pfcGetProESession();
    var model = session.CurrentModel;
    var selOptions = pfcCreate ("pfcSelectionOptions").Create ("point,edge_end,edge_start,csys");
    selOptions.MaxNumSels = 1;
    pointSel = session.Select(selOptionsvoid null).item(0);
    if (pointSel.SelItem.Type != pfcCreate("pfcModelItemType").ITEM_POINT) {
    var udfInstructions = pfcCreate("pfcUDFCustomCreateInstructions").Create("box");
    pointRef = pfcCreate("pfcUDFReference").Create("point"pointSel);
    var refs = pfcCreate("pfcUDFReferences");
    refs.Append(pointRef);
    udfInstructions.References = refs;
I am not good at English.... I hope you understand my question..
thank you !!
Hi Cyan
I think this Mat post could help you.
Best Regards
