using pfcls;
using System;
using System.Collections.Generic;
using System.Diagnostics;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace testOpenPrt
internal class Program
static void Main(string[] args)
Console.Write("请用;分隔序号数字,输入想要生成DXF的图纸\n所有打开模型将会关闭!!!\n");
string inputselest = Console.ReadLine();
IpfcBaseSession currentSeesion;
IpfcWindow Iwindow;
Connecting MYconnect = new Connecting();
IpfcAsyncConnection asyncConnection = MYconnect.asyncConnection;
currentSeesion = (IpfcBaseSession)asyncConnection.Session;
CCpfcModelDescriptor descModel = new CCpfcModelDescriptor();
IpfcModelDescriptor descModelC;
descModelC = descModel.CreateFromFileName(inputselest + ".prt");
Iwindow = currentSeesion.OpenFile(descModelC);
Iwindow.Activate();
public class CreoVBAPIProcess
public static void EndProcess()
Process[] a = Process.GetProcessesByName("pfclscom");
if (a.Length == 0)
return;
a[0].Kill();
class Connecting
public IpfcAsyncConnection asyncConnection = null;
public Connecting()
try
// Console.WriteLine("connecting");
asyncConnection = new CCpfcAsyncConnection().Connect(null, null, null, null);
//Console.WriteLine("Connection established to existing Creo Parametric Session");
catch (Exception ex)
if (!(asyncConnection is null || !asyncConnection.IsRunning()))
asyncConnection.Disconnect(1);
CreoVBAPIProcess.EndProcess();
Console.WriteLine(ex.Message + Environment.NewLine + ex.StackTrace);
//Console.WriteLine("Error occurred while connecting to existing Creo Parametric Session");
finally
I can open ",asm" and ".drw" file with this app,but when it coms to "prt",the program report "XToolkitNotFound ".
Here is the bug information.
System.Runtime.InteropServices.COMException HResult=0x80020009 Message=pfcExceptions::XToolkitNotFound Source=RunMarco StackTrace: at pfcls.IpfcBaseSession.OpenFile(IpfcModelDescriptor _MdlDescr) at OpenModel..ctor(Connecting MYconnect, String modelname, Int32 Buttonoption, String Macroname) in C:\Users\u214820\source\repos\RunMarco\Program.cs:line 112 at RunMarco.Form1.button1_Click(Object sender, EventArgs e) in C:\Users\u214820\source\repos\RunMarco\Form1.cs:line 43 at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData) at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.Run(Form mainForm) at RunMarco.Program.Main() in C:\Users\u214820\source\repos\RunMarco\Program.cs:line 24
Hi CZ_10363541,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
