I want to regenerate the current part/model – file with updated values. It works through vb.net process.
bsomasundaram
Now, I want to regenerate the current part/model – file with updated values.  It works through manual process.
If I try the below code it show some error, please help me.
Code:
If Not LmodDoc Is Nothing Then
                LmodDoc.Display()
                session.CurrentWindow.Activate()
                new_parameter = LmodDoc
                pro = new_parameter.GetParam("Z1")
                prov = CType(pro, pfcls.IpfcBaseParameter).Value
                prov = (New CMpfcModelItem).CreateDoubleParamValue(40.0)
                CType(pro, pfcls.IpfcBaseParameter).Value = prov
                pro = new_parameter.GetParam("Z2")
                prov = (New CMpfcModelItem).CreateDoubleParamValue(99.0)
                LmodDoc.RegeneratePostRegenerationRelations()
                session.CurrentWindow.Repaint()
                paramlist = ""
                powner = LmodDoc
                params = powner.ListParams()
                window = session.CurrentWindow
                window.Activate()
                window.Refresh()
                window.Repaint()
                session.GetModelWindow(LmodDoc).Refresh()
                session.GetModelWindow(LmodDoc).Repaint()
                Dim solid as pfcls.IpfcSolid
                If session.CurrentModel.Type = EpfcModelType.EpfcMDL_PART Then
                    solid = session.CurrentModel
                    solid.Regenerate(Nothing)    i am getting error in this area (attached files)
                End If
                LmodDoc.Save()
End if
Values are saved without regenerate process. I want regenerate process through coding for auto update the related values.
Balaji.S
0 REPLIES 0
