Hi guys,
I try to use .jar files within my jlink application.
What I did is to add those to the java_app_classpath within the protk.dat file.
eg.
java_app_classpath ./apps/Library.jar; ./apps/classes
java_app_classpath ./apps/Library.jar ./apps/classes
but neither did work, as soon as I'm calling a class within the .jar a ClassNotFoundException is thrown.
Would be really glad if anybody knows how to handle this.
thanks, that's good if you have multiple auxiliary applications using the same libraries.
in the meantime I figured a rather strange looking syntax for the protk.dat by dividing two libs with a ".;"
java_app_classpath /apps/lib1.jar.;./apps/lib2.jar
Thanks again,
Hello Paul
Add the additional jar files at the end or your java_app_classpath using semi colons in your protk.dat file as shown below.
java_app_classpath C:\project\jar\appJar.jar;C:\foldername\lib.jar;C:\folderName\lib2.jar
Hi guys,
eg.
