we are using Creo2.0 and Jre1.8.0_191
we have setted up the Environmental Variable in following manner
path : .......\jdk1.8.0_191\bin;.......\jre1.8.0_191\bin
java_home : C:\Program Files\Java\jdk1.8.0_191
PRO_COMM_MSG : ........\obj\pro_comm_msg.exe
CLASSPATH : .....M240\text\java\pfc.jar; .......\Java\jdk1.8.0_191\bin; ........jre1.8.0_191\bin
We have created a Protk.dat file and StartInstallTest file
in Creo Auxillary Application we have registred Protk.dat file & while Running we getting error START UP APPLICATION FAILED.
Do we need to set the Environmental Variable for pfc.jar which available in creo folder
Please help to resolve this Problem....
Thanks..
please see below mentioned information. Maybe it helps you to orient in the problem...
1.]
I tested StartInstallTest on 12-Jan-2017 with CR2 M190 (J-Link component installed) successfully.
I compiled java files using j2sdk1.4.1_07. See J-LinkCreoParametric2.pdf available via https://community.ptc.com/sejnu66972/attachments/sejnu66972/customization/2514/1/J-LinkCreoParametric2.pdf link
2.]
Today I tested StartInstallTest with CR2 M240 (installation without J-Link component).
I added following line into parametric.psf file:
ENV=CLASSPATH=E:\PTC\Creo2_M190_JLink\Creo 2.0\Common Files\M190\text\java\pfc.jar
I added following line into config.pro file:
JLINK_JAVA_COMMAND E:\PTC\Creo2_M190_JLink\Creo 2.0\Common Files\M190\x86e_win64\obj\JRE\bin\java.exe
java -version ... 1.6.0_13
StartInstallTest application works well using the above settings.
3.]
JLINK_JAVA_COMMAND C:\Program Files (x86)\Java\jre1.8.0_191\bin\java.exe
StartInstallTest fails during startup. I think Java 1.8 is not supported with CR2 ... ask PTC Support to get current information.
