I want to read data from Excel and use it as a filter.
Or to read the value of a specific parameter or directory address.
C is asking me to set up a link while browsing the library that reads xlsx or xlx.
However, if the project configuration properties are makefiles, no links are visible in the options.
add the LIB path to the makefile, the build succeeds.
However, the toolkit application does not run.
