1. Is there any way to clean up the MBD 3D annotations(Dimensions) in 3D model in the same way like a 'Dimension cleanup' command in Drawing/Detailing?
Also, Looking for any equivalent API(toolkit) or an algorithm that can be used to automate it?
2. Is there any snap line option in MBD as like in drawing/detailing in creo to do manually?
If so, is there any config option in Creo like(~auto_center_dimension_mbd) to set in 3D model for MBD dimensions?
We would be glad if you could provide as much as info on this or / any of the workaround that we can tried on this 3D dimension cleanup activity.
Hi MS_9932394,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
