Model view name and orientation name from View
Ketan_Lalcheta
Hello
We have view created into drawing file. We know we can set model view name and orientation name for drawing view using API ProDrawingViewOrientationFromNameSet().
Is there a way we can get model view name and orientation name for a view? We need to achieve this through Toolkit. We have Creo 4.0 M030.
Thanks and Regards
Ketan
FV
(To:Ketan_Lalcheta)
Hi all,
Ketan,
The API is missing and it was missing for the last 25 years.
The most useful workarounds:
1. create a set of ProParameters in a drawing where a parameter name is a drawing view name and the value is model view name. This works for use cases when the app would need to set up a drawing view and later on to see if a parent model view orientation had been changed.
2. this is just an educated guess approach - get a drawing view transformation matrix, normalize, remove shift and scale, map to model coordinates (drw_to_model_trf). In a model, visit named views, for each view get a view transformation, remove shift, scale, normalize and calculate dot products between drw_to_model_trf's vectors and view's transformation vectors - the resulting dot product values should be double-equal to 1.0 with some fuzz factor. The result of this should be one or more co-oriented model views and your app would have to make a decision which one to use...
HIH.
FV.
@Ketan_Lalcheta wrote:
Hello
Thanks and Regards
Ketan
I guess I don't understand your request but
  • tk_status = ProViewNameToView (model,pro_view_name,&view);
  • tk_status = ProViewMatrixGet  (model,view,matrix);
is not what you need?
Drawing Views and Model Views are not linked.
