ProFeatureStatus - feature status not working well with Rep Simp
When I change the simplified representation, and run an assembly visitor based on ProFeatureTypeGet and ProAsmcompVisibilityGet, I get the right structure (all excluded are not taken). But when it finished, all the inactive feature status refreshes to active. So on the next run,  I get the master simplified representation. I don't know why. Can someone explain me, the reason and how to avoid it?
InactiveInactiveNo Rep SimpNo Rep Simp
Thank you!
RPN
RPNAnswer
18-Opal
June 20, 2023
extern ProError ProSimprepActivate (ProSolid p_solid,
ProSimprep *p_simp_rep);
Purpose: Activates the specified simplified representation.
NOTE:
Operates on assemblies only, not parts.
Call ProSolidDisplay() to display simplified rep correctly.
You called ProSolidDisplay()?
RPN
RPN18-OpalAnswer
18-Opal
June 20, 2023
NOTE:
No, I didn't call it.
Thank you! 😊 Adding it, solved the problem.
