ProFileOpen a Directory
hdomi
Hi Everybody!
I'm programming a pro toolkit dll in wf 3.
I am trying to get a directory path through a ProFileOpen Dialog, similar to the function of the ProE Dialog for Setting up the Working Directory.
There is the ProLine filter_string as the second argument that filters the file type.
The idea would be adding a filter string that only allows the selection of a directory.
My question now:
Does anyone know the file type filter for a directory? Or is this actually possible with the ProFile Object?
If its not possible .. what would be a simple alternative?
thx in advance
Kind Regards
Domi
vinaym
(To:hdomi)
I would use ProDirectoryChoose()
Description
Prompts the standard file browser interface of Pro/ENGINEER, set upfor the
purpose of allowing the user to select a directory.
Vinay
2009/7/23 Dominik Hartinger <dominik.hartinger@cads.at>
> Hi Everybody!
> There is the ProLine *filter_string as the second argument that filters
> the file type.*
> a directory.
> My question now:
> thx in advance
> Kind Regards
> Domi
Dominik,
Try using the API ProDirectoryChoose().
Function ProDirectoryChoose
Description
Prompts the standard file browser interface of Pro/ENGINEER, set upfor the purpose of allowing the user to select a directory.
Patrick Williams | Sr. Applications Engineer | Engineering Systems | Steelcase Inc. | 616.698.4078 | My Site<">http://my.steelcase.com/Person.aspx?accountname=NA\PWILLIA3>
[cid:image001.jpg@01CA0E94.9F58DC30]
