Well assuming that you would not create a new level unless there are at least 2 items in the assy, you will have at least 2^24 parts in the assembly, which is equal to 16.7 million.
It does seem a bit excessive. I doubt anyone here has such an assembly.
If anybody does have one, you should contact the Guinness book of records!
Cheers,
Patrick Asselman
---- "daniele.zanella@tiscali.it" <daniele.zanella@tiscali.it> schreef:
> Ahhhhhhhhh, I get It, so I will try a more realistic paragon :
> From my point of view, triing to open/modify a 25th object level,
> is like open the garage, ( with the openers, of course 😉  ),
> while you are still on the highway
> Is better ? sounds good ?
> I worked for CAT in Italy, and I work with proe since 98,
> in a lot of different industries, from automation to tractor - to pavers,
> with huge assemblies with tonns of parts, and I never ( NEVER )
> face this issues,
> but I repeat, maybe I am wrong,
> But I would prefear that PTC spends his time ( and my money..... 😉  )  doing something more usefull than a 100th level modifiable assembly
> ----Messaggio originale----
