Good morning everyone,
I'm using Creo 10 and from the "Tools" ribbon menu I start my c# application.
We can do everything but in the "Model" menu a lot of function are disabled especially "Parameters". I don't understand why this happen when we start our application and from that application we are able to delete all the custom "Parameters".
When we close our app I thought the menu will be active again but this doesn't happen and if I do a right click in the assembly I have the icon for "Activate" it.
I tried these option:
But nothing is working. I have to close the file and open it again to check the "Parameters".
How can enable, with ProToolkit API, the menu during Close function of my application?
Thanks a lot,
Nicola
It is hard to tell, my guess would be, that you closed a window, which was activated by your code. In that case you must activate the current window by using CTRL-A. You can save the current window ID, and restore it on app exit,
I already tried with restore window ID () and was not working.
Today I try again only with this API function:
ProError status;
int window_id;
status = ProMdlWindowGet(curModel, &window_id);
status = ProWindowActivate(window_id);
This it's working good. Re-enable the ribbon menu and I can check the "Parameters".
