Hi All,
I wanted to know how to calculate start and end angle of an arc with the following data known:
1. Starting Point
2. Ending Point
3. Center of the arc
4. Radius
Any information related to this will be very helpful.
Thanks in advance!
Srikanth
Above information is required to draw a sketch (2D Arc)
It's basic geometry. You have a center point, you have two end points. Define a vector from the center point to each of the end points. Calculate the angle from each vector with respect to the reference axis (X axis, I believe). The only thing that might be tricky about it is if the function you are feeding these values into needs them in a range of zero to 360 degrees, or -180 to +180 degrees.
Thanks a lot !
As you said my main intention is to understand what values to be allocated in 2D arc structure. As you mentioned, will it be zero to 360 degrees, or -180 to +180 degrees.
