I'm not sure of the best way to do this, but I know it can be done from a previous job. I would like to create a table where the user can selection options like they would in a symbol and their selections would populate the table. Basically, I'm trying to create a "Applied Standards" table where the user can pick the relevant standards from a list and put them in the table automatically.
What is the best way to go about doing this? I don't really see a way to do it with repeat regions or in the symbol gallery.
Hi @TractorGuy
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Well, there may be a few approaches but there's not quite enough information in your question to answer completely. Some additional questions:
Maybe if you describe what the process looked like at your previous job, that would help us understand how to recreate that functionality. Or, if you can give further details about the number of standards you're trying to handle and the ideal output you'd like to see, that will also help.
Thanks!
PS: Of course I just realized you may want a toolkit application. None of the methods I considered use Toolkit - which would have far greater flexibility.
Hi @TractorGuy,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
