Resolve "exception pfcExceptions.XToolkitBadContext" when using Wed.link Solid::ExecuteFeatureOps()
YL_10965007
7-Bedrock
The  Article - CS325902
It said that
  • Creo OTK C++, OTK JAVA (both FREE & Licensed versions), VB API & WebLink APIs are enhanced to support Regeneration failure handling in no_resolve_mode. Hence, No Need to use the configuration option
But I am still having "exception pfcExceptions.XToolkitBadContext" when using Wed.link Solid::ExecuteFeatureOps() .
How to solve it?
Article - CS340286 can solve this issue.
I finally used the macro to replace this API.
Hi @YL_10965007,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team.
