Hi there,
it seems, that for all non-english installations and customers of Creo Parametric, the implemented and by default activated spell-checking is unusable.
Even worse, when the complete text is red-curled-underlined, the text is barly readable and makes it easy to miss a real typo.
I found this page, which addresses the issue: https://www.ptc.com/en/support/article/CS39069
But unfortunately (and usual), PTC does not provide a helpful resolution ( "no plan to fix" & "works in IE").
Does someone know, how to disable the embedded browsers spell checking or how to change the language for the spell checker ?
I figured out, that the language for the spell checker follows Creo's GUI language.
But it would be neat, if You could use different languages for GUI and spell-checking.
e.g. Though I use german for comments in Windchill, I use Creo's english GUI.
