Hi @ all,
I have a small problem. I created some Toolkit applications and since yesterday everything works like a charme. But in the late hours yesterday my Creo don't start anymore. If I remove all Toolkit applications everything works fine. If I try to start one of them syncron with the Creo start the Creo start crashes and don't react.
Have someone else ever have these problems and / or a solution for this? I don't want to reinstallate my pc also when I think this solves the problem.
Best regards,
Eike
I think I've had this same problem. It started after I set Creo to use my toolkit license to load non-unlocked plugins. It goes away if I take away the Toolkit license with the protkunlock application. I haven't found a solution to this yet and it doesn't seem to happen to anyone but me, so I just test my plugins with DELAY_START = TRUE in my protk.dat.
Pretty annoying!
Thx : ) The Creo starts, but when I start the TK App everything crashes again. : )
I've tested also to rename the creotk.dat back to protk.dat. Then eliminate the ribbon file. So Creo starts perfekt without the ribbon file. When I drag the start command out in the ribbon Creo crashes again.
So It seems like its a ribbon problem.
Aunt Edit:
After I restart Creo the buttons there. So I can work, start and stop my TK-App, everythink works fine. But never touch the Ribbon-Bar. If I change something in it, everything crash again.
