TIP: How to read model from windchill workspace
Aravind98
status = ProBrowserAuthenticate(username, password);
status = ProServersCollect(&aliases);
status = ProArraySizeGet(aliases, &num_servers);
for (i = 0; i < num_servers; i++)
status = ProServerUnregister(aliases[i]);
ProPath serv;
ProStringToWstring(serv, (char*)workspace.c_str());
ProPath URL;
ProStringToWstring(URL, (char*)serverurlw3.c_str());
ProName wsName;
ProStringToWstring(wsName, (char*)wsNamestr.c_str());
status = ProServerRegister(serv, URL, wsName, &aliased_url);
status = ProServerActivate(serv);
ProPath* p_file_name_array;
ProPath* p_subdir_name_array;
//string da = ".asm,.prt,*.drw";
string da = "*.drw";
ProName namme;
ProStringToWstring(namme, (char*)da.c_str());
status = ProArrayAlloc(0, sizeof(ProPath), 1, (ProArray*)&p_file_name_array);
status = ProArrayAlloc(0, sizeof(ProPath), 1, (ProArray*)&p_subdir_name_array);
status = ProFilesList(aliased_url, namme, PRO_FILE_LIST_LATEST, &p_file_name_array, &p_subdir_name_array);
status = ProArraySizeGet((ProArray*)p_file_name_array,&files);
for (i = 0; i < files; i++)
char _path[PRO_PATH_SIZE];
ProWstringToString(_path, p_file_name_array[i]);
wstring substring = //"Your Server URL";
wstring result = p_file_name_array[i];
string sPath(result.begin(), result.end());
partPaths.push_back(sPath);
size_t pos = result.find(substring);
if (pos != wstring::npos) {
result.erase(pos, substring.length());
string _name(result.begin(), result.end());
partNames.push_back(_name);
6 REPLIES 6
Take a look:
RPN
(To:VladimirN)
@VladimirN @You are funny, you did not check the initiator 😉
Aravind98
(To:RPN)
RPN
(To:Aravind98)
You see in the answer from “PTC”, they are working with message bots 😉
Hello @RPN,
Thank you for using PTC Community!
Actually, the reply is not from a Bot. In fact "VladimirN" is one of our very active contributor & a Community Champion.
Thanks & Best Regards,
Community Moderation Team.
RPN
(To:vnamboodheri)
Hello  @vnamboodheri I thought more about your answer, but this answer is no longer available 😀 Probably you can delete ...
For sure (as far of my english) there was an answer, where the chat content was most likely ignored.
But we don't need to discus this further 😉  I appreciate your work!
